Cannot Apply Boolean Variable to Variant
  • October 15, 2024
  • 4 replies
  • 471 views
Preston1
I was following this video tutorial and it seemed to have exactly what I needed. However, now that Figma has been updated to a new UI, this section of the tutorial no longer applies. How can I do this in the latest version of Figma?
Figma YouTube Link
Simply changing the variant’s appearance with a Boolean value is not a viable solution right now.
Best answer by Apolline
I had the same issue yesterday, but creating a regular variant property did work. If you just give it boolean “values” it should turn into a boolean automatically.
For more details on the issue :
Create a boolean property here
Then it’s impossible to find in the actual component/variants, you can’t apply it.
Also doesnt work in UI2 if I revert back.
Haroll
  • Active Member
  • 273 replies
  • October 16, 2024
Hi @Preston1
I’m not entirely sure what you’re looking for, so I have a few questions to better understand your issue:
  1. I watched the section of the video you linked, but I didn’t catch the part that no longer applies due to the new UI. Could you clarify what’s changed or no longer relevant?
  2. From what I understand, the tutorial demonstrate how to update a component’s state using variables. If that doesn’t align with what you’re looking for, perhaps this might not be the right tutorial you need. Could you share more details about what you’re trying to achieve, maybe with some screenshots, so we can better assist you?
Apolline
  • Active Member
  • 52 replies
  • October 16, 2024
Preston1
  • October 16, 2024
Thanks! This did the trick!
Talia_Rose
  • February 6, 2025
I don’t understand why Boolean is even an option when it isn’t working. 3 months later and I’m having the same issue. I can make a boolean property but there isn’t a way to actually apply it to the variant.
