Bug - Min Max size (width or height) not showing on component instance
  • August 29, 2024
  • 240 views
Dustin_Hansen2
There seems to be a bug where the Min and Max values do not show up on component instances?
The values do get applied, but they do not show up in the W (width) and H (height) fields, so there is no way to see that’s where the width is coming from, or to clear the min / max when an override is needed.
NOTE: this seems to happen only with nested components. In my example I have a button component, inside a “Button Group (Save or Cancel)” component. An instance of the button shows the Min width, but the button in an instance of the button group does not.
Possibly related: Can’t remove min and max height when the component is nested
Maria C G
  • April 12, 2025
Hi  Dustin,
I have the same problem. Did you find any solution?
Thank you!
Jack Lim
  • April 15, 2025
I’m also having the same problem. Couldn’t fathom the reason.
Erman Tutan
This happens with nested components. There doesn't seem to be anything to do except wait for an update to cover this issue. Simple but annoying :(
