Jen13
Sep 19, 2024 11:39 AM UTC
Best way of prototyping a highlight on an item in a list?
Hi there,
I’m sure this comes up a lot but I wondered what the best way of highlighting one item in a list of items is on click? I know I can change component variant on click but this won’t change the others back. Here’s what I need:
List of Items - Default Not Highlighted
Click on item - Highlight Item
Click on different item - Highlight this item but UNHIGHLIGHT other item
What is the best way of doing this?
This is the only way I can do it at present which is laborious and requires a new component for every version of the list. Seems like an inefficient way to do it!
Thanks
Jen
Pavel_Kiselev
Power Member
Sep 20, 2024 7:01 AM UTC
Well, it seems you can make it a bit easier with variables
This is how I did it. Firstly you would need a list component where each variant contains only one selected item
Then you create a variable to bound to the selected property of your list
Lastly, you make each list item to set a variable value. I use the multi-edit feature so I don’t have to touch every single list item in every variant I made
And now I have one
Pavel_Kiselev
Power Member
And now I have one
Pavel_Kiselev
Power Member
Sep 20, 2024 7:04 AM UTC
But for a list of 13 items you need to have 13 variants, still a big ouch
Jen13
Jen13Author
Sep 20, 2024 1:12 PM UTC
Thank you for that I thought something like that would be possible! I’ll give that a go.
Jen13
Jen13Author
Sep 20, 2024 2:08 PM UTC
This worked thanks! Thanks for mentioning multi-edit, hadn’t realised this was possible so that’s a life saver!
Pavel_Kiselev
Power Member
Sep 20, 2024 3:58 PM UTC
Glad it helped, cheers
