Schaltza
Jan 26, 2024 2:31 PM UTC
3 Column Layout: 1col = 1/3 and 1 col 2/3 width
Hi,
I’m wondering if anyone figured out how to have a frame that adapts to the height of the content but respects the grid?
This is what I’m trying to achieve:
Gayani_S
Jan 29, 2024 2:12 PM UTC
Hey Schaltza, thank you for reaching out!
Layout grids provide visual structure to designs. But I’d recommend to make the frame resize to its content. Is this what you’re trying to achieve?
The screenshots are from Figma’s Auto Layout Playground File:
https://www.figma.com/community/file/784448220678228461
Schaltza
SchaltzaAuthor
Jan 30, 2024 6:17 AM UTC
Hi Gayani,
No this is not what I’m trying to achieve.
I need a 3 column layout where one piece of content takes 1/3rd of the width and the second 2/3rds. I can do this with a regular frame using 3 col grid, however when the content in the 2/3 becomes too big for the width, the height of the frame does not adapt to the content. If I use the autolayout frame I can’t get the 1/3, 2/3 layout. It’s a known problem of Figma and I’m reaching out to the community if anyone knows of the work around.
Thanks for your help.
Gayani_S
Jan 30, 2024 12:35 PM UTC
Got it, thank you for clarifying! I’ve asked internally for any workarounds here. I’ll update you soon.
Gayani_S
Jan 30, 2024 6:22 PM UTC
Unfortunately, I was not able to get a good workaround here from the team, apologies for this! I hope the community will have a better solution for you.
May 27, 2024 12:13 PM UTC
I’ve been having exactly the same problem with this. I’m looking to move to Figma from Sketch and have a bunch of form input fields in my sketch designs (and text counterparts for when the form data is not being edited) 1/3-2/3; 1/2-1/2 and 2/3-1/3. This is something I can do so easily in Sketch, but whilst Figma is so good a some things, it seems anything other than a simple 50/50 auto resizing grid is beyond its means. Maybe I’m missing something but I’ve been trying to achieve this for over a day now.
dennsi
May 27, 2024 12:39 PM UTC
You can use Auto layout here and keep 1/3 + 2/3 layout with using max-width for the containers. Each Auto layout container is set to Fill (width) and Hug (height), has a max width corresponding to the columns and are nested inside an Auto layout parent container with its height set to Hug as well.
Feel free to check out my example file here and duplicate it to your Drafts to inspect it:
Figma – 27 May 24
Disclaimer:
However, when resizing the parent frame width the column ratio breaks at some point. A fully responsive layout would require percentage based width values, which is currently not possible.
Aug 16, 2024 4:42 PM UTC
Hey, does anyone found a solution for responsive css grid. i also try to solve kinda same problem.
iam trying to create responsive 3-6-3 column in a 12col css gris system.
The page
Full width image (keeping 16:9aspect ratio)
3 col empthy - 6 col full typography - 3 col empthy
Once i merge these as auto layout the second auto-layout behave (space between) and not keep 3-6-3 col grid.
if anyone have a solution?
ScottDaniels
Nov 18, 2024 6:09 PM UTC
Go to this page and upvote percentage-based use:
