Variant possible bug or limitation
Aysun_Sachir
Hello,
I have the situation where I’m trying to use a toggle with variations together with variable hiding/showing layers.
I’m really not sure if I’m doing something wrong or if I discovered a bug, so I was hoping if someone could help me.
The idea is to have the dropdown item hidden when the second option “zi” in the toggle is selected.
I managed to get it working with variables, but for some reason it only works on double click?
Am I missing something?
Thank you!
CleanShot 2023-07-07 at 12.58.59
Aysun_Sachir
One other I think I should mention is that the blue toggle is a component in an external library, with 3 variant types linked to each other “on click”.
Avokadomos
  • Active Member
  • 377 replies
  • July 7, 2023
Try reordering the actions so that the variable is set before the transition. Might be the same problem as posted here:
Aysun_Sachir
Thank you, this works, although not when I also have an external library, the component needs to be inside the file. Just wanted to point this out for anyone else searching.
  • August 6, 2023
