Variables: Cannot use it with the text property of as text component
The new variable feature is really awesome and opens a lot of opportunities but I don’t know why you can not bind a text variable to the text property of a component. I would love to create local text variables in my mockups in order to bind it to every wordings but right now, I can not. So I don’t know if I’ve got to rebuild all my text components and remove the text property or wait for an update … I don’t understand how and why they missed it.
Target_Santana
Agree! Please modify the text property to include the variable. Working with UX writers will be simpler, especially when translating copy into different languages.
Regards, Figma!
Natalie_Doronina
Try here, in text style section:
IraX
  • Active Member
  • 145 replies
  • June 25, 2023
@Natalie_Doronina — What they’re referring to is the text property used in components. While it’s true a text variable can be applied to a text style, it’s not currently a feature for component text properties (even if the text layer in the component is linked to a style).
Kyle_Rawding
Agreed - this was literally the first thing I wanted to do with variables. The new variables functionality gets us SO CLOSE to being able to type directly into prototypes (with enough keypad interactions set up) but this is a last hurdle. (along with multi-key inputs of course)
user298
  • June 27, 2023
I too would like to set the text value of Variables to a component property, I am planning to use Variables to manage the text content used in the product, but currently I have to give up using it in conjunction with component properties. I hope this feature will be added.
twitter.com
Evie
  • 7 replies
  • June 27, 2023
This is very important, since we make extensive use of the Properties for labels, values, etc. (It makes it a lot easier for the designers than clicking in to the text.) I don’t want to have to unbind all those Properties, but I don’t want to limit our prototyping capabilities.
Massimo_Valerio
YES! please this is too necessary!
AlicePackard
@Kyle_Rawding, providing users with a mostly working keyboard experience using variables is possible! @Levi_Jones seems to have cracked it:
twitter.com
Here’s the community file: https://www.figma.com/community/file/1255367798948126636
Levi mentioned in his twitter thread that backspace isn’t really available, it clears the entire input.
Kyle_Rawding
So cool! I work mostly on desktop products, so I did a similar method with 26 keyboard input variable interactions set up on the same text field, but recognizing capitals doesn’t work well without the explicit caps-lock button.
It is pretty essential, I was trying to components with Localization and I realized I can’t link local variables to component text when text has a property attached from the HOC wrapper.
Please put those on the road map
  • August 14, 2023
+1 This should be prioritized as it feels fundamental to be able to localize components within a design system.
Having to detach components and attach variables feels like it completely defeats the point entirely - as changes then become massive pain points, vs updating the design system at large.
Kseniia_Afrikantova
Yep, even to make a simple select field prototype, I need to destroy my text properties and replace them with variables. Other way I can’t paste a selected list item text into the value.
Rebecca_Dantas
+1 Yes, please! I cannot localize components from my Design System due to this limitation and the Variables end up being pointless in this case. This should definitely be prioritized.
Shingo_Suzuki
According to this article, Figma is working on the ability to apply variables to component properties.
Figma Learn - Help Center
Additional component property types: Currently, you can only assign variables to variant properties. We’re working to support additional component property types.
  • December 13, 2023
