SVG Export Issue
Show first post
Alice15
  • September 13, 2023
This is a really frustrating issue. The company I work with use Figma for most of our design work and most of the time it works really smoothly and is a great tool…however whenever I need to export SVGs it ALWAYS let’s me down. I’ve returned to this thread multiple times over the last year expecting it to have been resolved, but I can see this has been an issue since 2021 and is still ongoing. I don’t want to have to rebuild my designs in illustrator every time I need a working SVG. I don’t want workarounds to strokes or masks, there is often very little time to rebuild assets for this. With this many people reporting the same issues, surely there must be a way to fix it? We don’t have time to upload our working files and give a detailed bug report every time the same thing happens!
I agree with you. I’m experiencing the same issue currently. Don’t have time to recreate the assets in illustrator.
Vanessa_Gadberry
+1 Need a solution as a Creative Director managing a team of visual designers, do NOT want the Illustrator/Figma workarounds… Not at all feasible.
Thank you. Can’t imagine the rabbit-hole I would’ve went in if it weren’t for this.
Impressive to see that nothing has been done since (at least) 2021 regarding SVG exports.
It’s quite annoying and distrubing productivity not be able to export a single SVG shape without wrong dimensions / width / height, still to this date.
Being forced to replace every vector manually in Illustrator to fit the expected 2px border width that became 3.5px for no reason after export is really some BIG waste of time.
Community would love some attention here @Josh
  • January 18, 2024
Unchecking the option “Simplify stroke” at the export fixed the problem for me.
experience_number_1
I am new Figma user so I am still not sure if it will work on all of the cases. But I had a problem that my stroke + effects were not exported throught svg file. I solved it by doing a selection on all the figure (The Icon I wanted to export to svg file) and than exported it in svg file.
Carolina4
When I export an svg from Figma, all the names of the layers are missing. Help
Zoe_Bartley
Like other above - Still having issues with quality, accuracy and code export of icon to SVG!
  • 2320 replies
  • February 11, 2024
Hi all,
We hear you frustration and our apology for the longstanding issue. If you continue to see exporting SVG issues, as SVG Export Issue - #16 by Gleb, could you reach out directly to the support team with;
  1. Screenshots
  2. Exported SVGs
  3. Original Figma file links, and
  4. Info on where and how you are viewing the SVGs
Thanks for your patience.
Toku
  • February 23, 2024
Same here. Adjusting the stroke to center fixed the export issue. Thank you!
Dmytro_Korolkov
Thank you!
Massimo.Fiorentino
Exactly. It still seems like an issue as I write this. Outlines are a problem—and centred strokes at that. But even when outlining the strokes, you can have problems. Centre, then outline and check for crossed sections, which seems the only way around this.
