Prototype section twitching when scrolling (BUG)
Yanick_Jimenez1
When I scroll to a section, I notice some strange twitching on my prototype preview (https://www.figma.com/proto/EIp5AMvs4fQsSF4bnOnk45/Scrol-Bug?node-id=2%3A11&scaling=scale-down&page-id=0%3A1&starting-point-node-id=2%3A69)).
I enabled “Preserve scroll position,” but it still does not work. I looked online for answers but couldn’t find any…
I’m hoping someone can assist me here. Here’s the document I’m using as an example of the problem I’m having: https://www.figma.com/file/EIp5AMvs4fQsSF4bnOnk45/Scrol-Bug?node-id=0%3A1
Valerija_Jurgaityte
Hello Yanick,
You have put an interaction that happens right after the first one instantly, thus the transition is barely even noticeable and can be defined as a twitch…
To fix the issue:
  1. delete the interaction going from frame “X - 6” to frame “X - 5”.
  2. Copy/paste the gray columns from frame “X - 5” to frame “X - 6” in the order it comes & clip the content.
  3. Make sure the purple and gray columns that are in “X - 6” frame are not in fixed position.
  4. Now add interaction from the “X - 6” gray columns to frame “X - 5”:
    Mouse enter > Dissolve > Ease out > 300ms > Preserve scroll position
I highly suggest to play around with “On drag” trigger, as it should be more suitable to imitate an interaction. “Dissolve” transition is what I like to use with transforming navigation, but “Smart animate” feature is great to play around with too and is very useful at times.
I really hope this reply was of helpful
Valerija_Jurgaityte
p.s. suitability of “on drag” is based on the prototype being a touchscreen
Yanick_Jimenez1
Hello Valerija!
It worked!!! 😃
I used smart animate as the prior didn’t work as instructed unfortunately. I’m definitely going to start using smart-animate more often.
Thanks for this very useful help
  • June 7, 2022
Aline_Ferreira_Scussel
Ultimamente, quando vou apresentar o protótipo, independente do tamanho do device, ao scrollar a tela fica tremendo. Alguém pode me ajudar?
  • 4825 replies
  • May 31, 2023
Hello @Aline_Ferreira_Scussel,
We’ve merged your topic with an existing similar one that may help with your issue.
If you continue to have trouble, please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so they can take a closer look.
