Problem: Vector (SVG) will also strech if I strech frame
  • February 4, 2021
  • 5 replies
  • 15546 views
Sheikh_Zahid
I am very new to this product and started designing without taking any class for this, this is really easy.
I started with a blank frame (canvas) started placing images and text and vectors (vectors and images are imported by file CTRL + Shift + K) now if I need to expand length of frame so I can design there, some vectors (not all) will be either stretch with canvas or displace.
Could not figure out frame connection with placed vectors.
Best answer by Steven
Oh well, you just need to understand constraints
Check this little 4min video
Steven
  • 122 replies
  • February 4, 2021
AmodeusR
  • September 30, 2021
I didn’t get what should I do 🤔 I tried virtually all the combinations I could think of with this “constraint” thing, and the SVGs I imported keep stretching when I try to increase the frame’s size.
Nina_Gorski
i was having the same issue, but figured out the solution from this video (though it wasn’t clearly said.) Select the vector image, and then on the constraints panel to the right, set the top level constraint. This sets the vector to remain the same distance from the top of the frame, so that it doesn’t move/stretch when updating the frame height.
AmodeusR
  • October 30, 2021
I figured out you can also just hold ctrl while resizing the canvas and you’ll be able to resize it very easily.
  • 4710 replies
  • October 31, 2021
This topic was automatically closed after 22 hours. New replies are no longer allowed.
