Problem Exporting images. Figma says "Downloading images" and keeps there without exporting
Show first post
Same problem.
Closing and reopening Figma solved this for me
the same issue I have here. I have closed managed to download 2 images and then the issue came back for the 3rd image.
  • September 28, 2023
Same here, already reinstalled Figma but it dit not fix the problem
Same here, only just started happening for me after I switched laptops. Is it to do with processor capabilities?.. I hope not!
Making a new board takes up far too much time when we’re doing so many assets a day, and is only a temp solution before the problem arises again.
Steve40
I’ve got an Apple M2 Pro and the same issues. Might be a server problem. Reinstall, move to another new Figma file and delete cache did not work out for me. It’s super annoying because I’m on a tight deadline -.-
exporting images still doesn’t work
After the recent update I was experiencing the same issue when exporting photos/images. I closed my tab and restarted Figma and that worked for me. Hope this helps.
2017 iMac 27in running Monterey.
Benjamin1
Same problem this week. Restarting Figma or the tab works but only momentarily. The bug returns after a few exports
Marina_Zlydennaya
I have the same issue with exporting for the whole day after recent update. Sadly, closing app and reloading don’t help much, but sometimes it works.
Steve_Kendall
This issue is still occuring, as others have mentioned the only way past is to restart the app, dont close tabs even, just restart to get through
I have no idea why this is the fix but it is…
John_L
  • Figmate
  • 28 replies
Hi all,
Thanks for the reports. Is the issue still happening even after you reload the tab? We believe the issue should be fixed now, but please let us know if you are still seeing it even after a force reload of the tab.
If the issue is still happening, what is the specific operation that is causing it? Is it “save local copy” or “export” or both?
John
Just the same
Petr_Siroky
  • 18 replies
Restarting Figma helped, but I’ve never experienced this hangup before. I was using export.
Lisette_Beentjes
Screenshot 2023-09-29 104519
Had the same problem. Restarted Figma and it worked again, but lost a lot of time trying to figure out what was wrong.
I got same problem. I use ctrl+shift+c to copy as png, every restart of Figma gives me only one png, then the problem happens again. I have to keep restarting again and again, until i have my 50+ pics a day done
Aothany
  • September 30, 2023
It’s been going on for 2 hours. I don’t know what to do
FT_Tom
  • October 10, 2023
Still a problem, this is beyond ridiculous
Still the same for me as well
margaritalunae
Same for me. However, it started to appear just recently. Quite inconvenient. Sometimes simple page reload helps but keeping reloading for every pic both tiresome and unsuitable for heavy projects/slow connection.
I use “export” for jpg and png.
belka
  • October 23, 2023
Ruy_Rebollo
Still happening, this is super annoying…
Marco_D_Ottavi
I have the same problem too, it’s really frustrating. I also tried uninstalling and reinstalling the application, but nothing. Is there really no possible solution?"
  • 2545 replies
  • February 5, 2024
Hi all, thanks for flagging. If the problem persists after basic trouble shooting, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new
as Ryan said
Thanks
