Multiple-Cursor feature to override multiple text fields
Oscar
Problem
Figma has no option to override multiple text fields at once
Possible solution
A Multiple Cursor feature like the one found on coding editors.
You could select all the text fields you want to edit with shift + click and then hit Enter and this could enable the user the change the value of the selected text fields, without affecting their text styles.
Example:
Mr.Biscuit
Before any of this happens, I’d like to introduce you to Add numbers to texts
Oscar
  • 12 replies
  • March 5, 2021
This helps a lot 🙂
Saeed_Alipoor
Instead of multiple cursors that can be confusing, I think it’s necessary that users could link text layers together, so if any of them changed all of the linked text layers should update.
jonoyoung
  • 34 replies
  • January 4, 2022
Would triple ❤️ multi cursor support in Figma. Hold Option to insert cursors.
This would be a great time saver when working with content/text/copy from a website where random elements get pasted and then have to be manually deleted one at a time.
