Multi selection to hide variable when publishing
XavierV
Hello,
I have a lot of variables, and when it comes to publish my library I don’t want all my variables to be published.
Today the only option is to open one by one the variable’s settings panel and check “hide when publishing”. When you have 3 variables it’s ok, but for 50, 100 or more it’s a monstruous waste of time.
For the record I had the exact same problems with Style when publishing.
Cheers.
Xavier
XavierV
  • 26 replies
  • August 24, 2023
I’m may be the only one with Core tokens I don’t want to share ? 😃
Fred_Tinsel
  • Active Member
  • 112 replies
  • September 2, 2023
I understand 😀
For the moment the variable’s UI is a pain…
Copy/paste ?
Enable/disable?
Move, export…
Julia57
  • Active Member
  • 42 replies
  • September 29, 2023
@XavierV You can move your core tokens into a separate variable collection, then simply uncheck the whole collection when u publish. You can also hide from publishing by naming them with a ‘.’ prefix, similar to components 😃
XavierV
  • 26 replies
  • October 3, 2023
Ok tks Julia, I will try to hide from publishing an entire collection. I cannot renamed my variables because they are tokens synced with Token Studio.
Bill_McCrery
Figured out if you shift select all the variables you want to hide, you can right click and choose “Edit variables” and hide all from publishing at once.
  • January 7, 2024
