Inconsistent behavior when inheriting text in a component
Jesus_Vera
PROCESS / RECREATION
I have built a system to managed the copy by component inheritance.
  1. I create a base text component. I set it in any typeface with 16/100% as a base font style.
  2. I use an instance of said component to create another one called “Copy”. Each variant has a different content I can call for when needed.
  3. I use an instance of “Copy” and I create another component called “Size”. The first variant is just an inheritance of “Copy” with no modifications. To the second variant I apply a different font style, which changes its size.
  4. Now I can deploy a block of text to render on the screen with the desired size and updated content
BUG
The system is inconsistent.
For some reason, sometimes when applying a different font style it overrides the the actual content. It does not matter if I manually change the font settings either.
I have side to side to components of exact architecture and different behavior.
PROPOSED SOLUTION
Font styles are no longer registering as an override in content for text components.
Best answer by Ryan_52
Hi @Jesus_Vera sorry to hear you’re having trouble! The forum is primarily managed by the community.
Please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Be sure to include a video showing the reproduction steps, include any links to the file, and share it with support-share@figma.com so they can take a closer look.
Jesus_Vera
  • June 11, 2023
Ryan_52
  • Technical Quality Specialist
  • 382 replies
  • June 13, 2023
  • July 13, 2023
