How to get list of system fonts while developing plugin
Brijesh_Dhanani
I’m developing figma plugin using ReactJS and want to get list of font families that’re installed in computer. Is there any way to get them?
  • 4709 replies
  • May 7, 2021
Do you want to get list of font families installed on the computer or the ones that are available in Figma? These are two separate things. I’m not sure how you can get all installed on computer (try to search the web, it won’t be different in a plugin from a normal website. But getting all fonts available in Figma is easy: https://www.figma.com/plugin-docs/api/figma/#listavailablefontsasync
Brijesh_Dhanani
Thanks @Gleb for reply. I want to get list of font families installed on the computer not which are available in figma. I searched a lot in web but didn’t find any solution.
I noticed that figma is using this route for getting local system font families. http://127.0.0.1:44950/figma/font-files which is of local computer path. Can I use that one for the same?
  • 4709 replies
  • May 7, 2021
You probably can’t get local fonts, this is not something web browsers allow you to do. That’s probably why Figma is using the Font Installer app which allows them to use this local system path to get fonts. So if Font installer is installed on the computer, you may be able to use this in the plugin, otherwise no. So your plugin would only work for a portion of users, if this idea would work at all.
Brijesh_Dhanani
Thanks @Gleb ,
Will it be good if I use this path to get fonts http://127.0.0.1:44950/figma/font-files ?
  • 4709 replies
  • May 7, 2021
I’d say no because there are no official apis for this and it could always change without your knowledge and your plugin would stop working entirely, not only for the portion of people.
Brijesh_Dhanani
Okay Thanks.
Then I think there’s no other way to get system fonts right?
  • 4709 replies
  • May 7, 2021
correct
Brijesh_Dhanani
Thanks @Gleb
Guillaume_M
Hi all, hi @Gleb,
I am trying to list all the fonts used in a Figma Files (or in a frame). This would be a subset of the value returned by listAvailableFontsAsync.
Would it be possible to do this without looping over every bit of every texts ?
Thanks a lot !
  • 4709 replies
  • February 3, 2023
No, the only way is to loop through all texts. Luckily you can do that pretty quickly using findAllWithCriteria | Plugin API
Guillaume_M
Hi @Gleb , thanks a lot for your quick reply. i’ll try this.
Bests
