How to add image asset when creating a plugin
  • September 28, 2022
  • 7 replies
  • 2525 views
Olushola
I am creating a figma plugin and I cannot add an svg image to the ui.html, please help
Best answer by tank666
figma.com
tank666
How do you add SVG to HTML?
Olushola
  <img src="search.svg" alt="" width="120">
Please note that the SVG and ui.html are in the same directory
tank666
  • September 29, 2022
Olushola
This worked, thanks for the help
Olushola
I have another problem though,
I used figma.ui.postMessage('msg') in my code.ts file to send a message to the ui, then I listen to the message in ui.html using onmessage = (event) => { console.log("got this from the plugin code", event.data.pluginMessage) } but I do not get any response in my ui.html
tank666
  • October 1, 2022
I’m not sure why this happened, because the code is correct.
So you don’t see the line got this from the plugin code msg in the console?
Olushola
After I debugged for a while, I found out onmessage = (event) => { console.log("got this from the plugin code", event.data.pluginMessage) } should come immediately after opening the ui.html <script> tag.
I think my issues have been resolved successfully.
Thanks for you help
