Duplicated component set cannot be published to Library
Hampus_Svallfors
Is this a bug?
My steps:
  1. Created a new component set by duplicating an existing and edeting that.
  2. The new component set show up under “local components” as expected.
  3. Team library list show the file as “Published and up to date”
  4. No changed to the component set triggers “Publish changes…”
  5. File is labeled “Current file has changes”, but Publish is disabled (unless I change any other component).
  6. If I copy the component to a new file. It is pasted as an instance, but it does not show up in the library list when I select it. All component variants and properties seem to work as expected.
  7. I have removed and republished the file to the library. No change.
Best answer by Hampus_Svallfors
Issue solved.
I had unused properties. When removed, the component could be published.
tank666
  • 4870 replies
  • March 8, 2023
If you encounter some kind of bug, you need to submit a bug report to the support team.
Hampus_Svallfors
Issue solved.
  • April 7, 2023
This topic was automatically closed after 30 days. New replies are no longer allowed.
