Convert to Frame
  • August 30, 2022
  • 7 replies
  • 9656 views
B117
I would love to purpose one real quick thing: What if we have an option to convert a shape to a Frame?
TY!
Lisa_Lessenger
Are you suggesting that a star would be the shape of the frame?
Avokadomos
  • Active Member
  • 377 replies
  • August 30, 2022
You can right click and select frame selection, and then just delete the shape. Almost as quick. This plugin does the same thing:
Figma
B117
  • August 31, 2022
It definitely works, but I seem to have found a bug, if you try to move any object/shape inside the frame, kinda of bleeding, created via “Frame Selection” the object pops out.
If I create a frame and move the same object inside the frame, it works.
Avokadomos
  • Active Member
  • 377 replies
  • August 31, 2022
You have to check clip content on the frame for objects not to be visible past the edges.
Sorin_Jurcut
Not really sure why this is a thing to begin with. I guess it’s a bad behavior migrated from XD/Sketch. In figma, there are very few cases where you would really NEED to use rect instead of frame or autolayout.
So, trying to add a very limited case feature would bring very little benefit as opposed to changing your work style. Imo
Avokadomos
  • Active Member
  • 377 replies
  • September 1, 2022
Maybe not for rectangles specifically, but if you think of rectangles as a shape, then it makes more sense. You can’t edit the shape of a frame, while rectangles can be distorted in all kinds of ways.
  • November 30, 2022
