Constraint Left and Right disabled when frame is set to fixed on scroll
Shukri
If I have a frame set to be fixed on scroll, I cannot select its constraints to be “Left and Right”. I have to move to the prototype tab, set it to “scroll with parent”, then set the constraints, and then move back to the prototype tab to set it back to “Fixed”
I don’t understand why fixed items cannot be set to “Left and Right”, but at least before, setting a frame to be fixed was just a checkbox above the constraints that I could quickly toggle on or off. Now, if I group frames that were set to be fixed on scroll, I have to reset the constraints, and its become a bit of convoluted process.
Best answer by djv
Hey @Shukri, sorry for the trouble!
Thanks for taking the time to reach out about this! This is a bug that we’re already tracking, where the “fix position when scrolling” disables certain constraints.
We don’t have a timeline of when a fix will be available yet, but the best workaround in the meantime is to continue how you’ve been doing with unchecking “fix position when scrolling” first to adjust the constraints.
Keep an eye out for a future release that launches the fix.
Arunava_Basak1
Hi all,
I have been seeing this problem for quite some time so thought I should let you guys know. The constraints “Left and right” “top and bottom” and “scale” on elements don’t show up when “Fix position on scrolling” is on. This always makes me turn off the checkbox and turn the constraint on and then revert back by enabling the checkbox.
Attaching some screenshots for the same:
  1. when checkbox is on, it does not allow using the constraints “L&R” and “Scale”
  1. Turning off the checkbox and selecting the constraint
  1. Turning on the checkbox after selecting
This makes it a little unintuitive and uses several clicks when it could work in just two clicks. Is there any reason it is built this way. can this be fixed?
Thanks in advance.
Shunsuke
  • 5 replies
  • December 18, 2021
I’ve been feeling same thing. Fix position + Left and right constraints would be like style="position: absolute; left: 0; right: 0" in CSS.
Tim_Torres1
  • February 3, 2022
I’ve been experiencing the exact thing, feels like a bug…
Eduardo_Clauman
Any news about this bug?
Peter_Sharpe
Just bumping this topic. As a new user I was confused why it wouldn’t allow me to constrain while the “Fix position when scrolling” checkbox was enabled. It’s particularly tedious when the layer drops down and gets hidden by other layers…
Prateek_Thapa
Bumping it again, having all constraints available for fixed elements seems necessary.
  • 4831 replies
  • May 5, 2023
Honestly Figma: this is a major bug and it is really annoying. Please fix this.
There can be no reason to block the constrains this way. No: obviously there is none, otherwise the annoying workaround (switching from “Fixed” to “Scroll with parent”, change the constrains to left and right, Top and bottom or scale and then switching the scroll behavior back to “Fixed”) would not work.
Please, please, pleas fix this!!!
seb8
  • May 23, 2023
Same problem here, made worse by removing the fix-position-checkbox. prior to that at least the checkbox was next to the constraints widget, now you have to switch between the design and the prototype tab. +1 for a fix!
  • June 3, 2023
lol.I thought i did not know what i was doing days ago. Its actually a bug 😆 .
Same problem today, not possible to apply left and right constraint on drop-down item of the select component (drop-down : absolute position).
  • July 22, 2023
Hi I have two sub-layers that one have left and right contrain option enabled but the other unable is greyed out. How do I troubleshoot?
luis.carmona
The solution of:
  • unfix position
  • select left + right
  • fix position
used to work for me, but not anymore 😦 anyone else?
Caesar_pb
  • 4 replies
  • September 1, 2023
Thanks for this reply! I just did what you said and it worked. For me at least.
Apparently you have to set the constraints parameters you want before you fix it on scroll.
Kingery_Michael
this hack doesn’t seem to work now that the “fix position” checkbox has been moved into the prototyping tab dropdown. I feel like i’m taking crazy pills - why can’t i just anchor these elements left and right while avoiding scroll?
Shikha
  • September 28, 2023
Any update on this?
Oksana_Butkaliuk
Hi there! You did a great product upgrade this summer but didn’t decide the issue with constraints… Am I sure?
Omar_Chelbat
It’s been years and years now. When will this be fixed? You moved the settings for scrolling under the prototype tab, which has made it even more of an annoying thing to manually change.
Can this please be prioritized? I’m amazed at all the weird, super niche, and buzzword updates we’re getting … but the core functionality issues, like this one, just remain in the product.
The irony of a UX tool having such terrible UX is palpable.
alexrest
  • 12 replies
  • December 15, 2023
+1 to fix this bug please 🙏 ☺️
Cristian_Banu
  • Active Member
  • 115 replies
  • January 17, 2024
Hi guys,
Sometimes, not very often, I get the LEFT AND RIGHT and TOP AND BOTTOM contraints disabled for certain elements. Just like in the example below for the main menu
Figma – 17 Jan 24
Does anyone know why in the world this is happening? Is this a bug?
Thank you kindly,
Chris
Raphael_M
  • 394 replies
  • January 17, 2024
Hi, Chris.
This is a bug that is currently not yet fixed. For the meantime, you can do the work around where you will set your header to scroll with parent, adjust the constraints, and then get it back to fixed.
Cristian_Banu
  • Active Member
  • 115 replies
  • January 17, 2024
Hi Raphael,
Thank you for replying. I think I also found a workaround, dragging the bugged components out of the parent frame and putting it back in it will solve the problem.
Raphael_M
  • 394 replies
  • January 17, 2024
Yeah. You can also do that to remove the Fixed state. Anyways, no problem 😀
Dennis_N
  • 188 replies
  • January 24, 2024
If the component has a min or max width, the pin left to right also is grayed out. It took a bit until I relalized that. I assumed that you can have a min and max width AND pin it to the left and right within the given range. Unfortunately not the case.
