Bug when using Variable Modes in Prototypes
S_e_b_a_s_t_i_a_n
Hey, i played around with the new variables feature. When I use variable modes (I created a Light & Dark mode) and use an animated component like the Button component in my example, it starts flickering on hover (only for dark mode, light mode is default).
To me it looks like, the component tries to get the default mode color first, then renders the dark mode color.
Design: https://www.figma.com/file/tAZmIsYLTdm97XlJUE67Kk/Tokens-Flicker-Bug?type=design&node-id=59985%3A54547&mode=design&t=q1yv6dBZIgWiVyXG-1
Prototype: https://www.figma.com/proto/tAZmIsYLTdm97XlJUE67Kk/Tokens-Flicker-Bug?page-id=59985%3A54547&type=design&node-id=59985-54548&viewport=-470%2C181%2C0.32&t=CW125CAj204AVmpQ-1&scaling=min-zoom&starting-point-node-id=59985%3A54548&mode=design
Nelson_Vasconcelos2
This is also happening to me. The text from the elements of my prototype are associated to variables with modes, and they are messing up on all elements with hover (e.g. buttons).
Ryan_52
  • Technical Quality Specialist
  • 382 replies
  • June 29, 2023
Hi, thank you for reporting this to us! Our engineering team is actively investigating the issue to determine its root cause and working towards a solution.
S_e_b_a_s_t_i_a_n
Cool, thank you Ryan.
  • July 30, 2023
