Plugin uninstall
  • September 1, 2023
  • 8 replies
  • 1063 views
Dishan_Anuradha
Is there any option to uninstall plugin or remove from recent?
Best answer by IraX
@Marian_Brchan — It changes based on your origin. Directly from Resources, it will be “Saved and recent”. From Plugins > Find more plugins… or Main menu > Plugins > Find more plugins…, it will be “Recents” (which also persists until another selection is made in that dropdown).
Overall, this has been an ongoing struggle for quite a while. The process of managing plugins has changed a lot over time and at this point it’s deteriorated to being seemingly impossible to remove them.
However, I’ve found that if you sign out of your Figma account, then sign back in, this will remove the recently used plugins, leaving only the saved plugins.
Kind of bizarre, but at least possible.
Marian_Brchan
You should be able to remove it by clicking the bookmark icon on the right.
Dishan_Anuradha
I want remove these.
Capture
Marian_Brchan
Oh right. I guess there’s no way to remove these.
What’s interesting is that you have in the dropdown only ‘Recents’ but for me it’s ‘Saved and recent’ and I have in the list all saved plugins first and at the end recent ones.
Dishan_Anuradha
There was a 'Manage plugin ’ option in settings; it’s not available in new versions.
IraX
  • Active Member
  • 145 replies
  • September 3, 2023
Dishan_Anuradha
Thanks for yor answer. Cristal clear.🙏
I’m using the desktop version of Figma, how do I remove the plugin? I’ve read remove it from local storage as “its not installed”, but for the desktop version how do I get rid of a plugin?
  • 3483 replies
  • December 5, 2023
Hey @BayArea415! The list of recent plugins is stored in Local Storage. Clearing this storage will clear out the list of recent plugins and other Figma settings.
Here’s another workaround how to clear the desktop app cache on a Mac:
  1. Quit the Figma desktop app
  2. Open Terminal.app and enter the following command: rm -rf "$HOME/Library/Application Support/Figma"
  3. Try opening the desktop app again
And here’s how to clear the desktop app cache on Windows:
  1. Close the Figma desktop app
  2. Open the Start menu, and paste in this, followed by enter: %APPDATA%\Figma
  3. In the window that opens, delete the Desktop and DesktopProfile folders if they exist
  4. Launch the desktop app again
Hope this helps!
