Figma Desktop crashes when opening a project
Hey. Today I was working on my projects, and as soon as I closed the Figma app in my Windows machine, when I reopened it started crashing when opening any project file.
I’m able to enter the main screen, but not projects.
I reinstalled the program, deleted the /Roaming/ and /Local/ folders… Nothing works… What can I do?
Thanks
Carol_Pessoa
It is happening with me too, I tried everything, but it keeps crashing…
bristy_bristy
Having the same problem shows Figma agent has stopped working
Blogoman
  • 4 replies
  • December 7, 2022
Same here.
Also from today Figma Agent crashes when opening Figma in Chrome or Firefox.
Mohammad_Hashemi
Same problem unfortunately 😭
bristy_bristy
I found out that Figma now requires windows 8 or later. where my pc is windows 7. Is it the main issue for not opening the desktop app?
Archie_Shell-Shocked
i got same problem. Here what i do to fix this: Figma crushing and it's solution for it
Works on my windows 7 machine
pechenka
  • December 7, 2022
Same. The desktop version does not work
Design_Techart
what version of windows?
windows 10 - program running
windows 7 - error
Natalya_Zhoglik
same problem, something is wrong with the updates. I also want to find a solution to this problem
  • 9 replies
  • December 7, 2022
Im not sure if it’s just a bug on Windows 7 but my thoughts for this is that Figma team dropped support for Windows 7 (On W10 works fine). As the program is a web based tool, I don’t think there is a workaround for this…
I hope I’m wrong and maybe is just a bug on this OS versions and can get fixed soon.
  • 9 replies
  • December 7, 2022
The workaround that @Archie_Shell-Shocked found is working
This is what to do:
  1. Get app-116.3.8 (Figma crushing and it's solution for it - #3 by Archie_Shell-Shocked) and place it in C:\Users\YOUR_USERNAME\AppData\Local\Figma.
  2. Rename or remove the other packages starting with app… and remove Update.exe
Seems that older version don’t crash the app on Windows 7
I can confirm this is working. Thanks
Igor36
  • December 9, 2022
Guys this work just for one time, after next start app not work again
Ant also Figma agent crushed every time
BLVCKBEAT
  • 4 replies
  • December 9, 2022
I just uninstall windows 7 , and install windows 10 🙂
  • 9 replies
  • December 9, 2022
It does work, just make sure to remove full control permissions for the folders, so Figma can’t replace files
  • 9 replies
  • December 11, 2022
Personally, I would like to get a response back about this recent change from the Figma team; has Windows 7 support been discontinued? (In the Figma Browser Requirements it says Windows 8.1 is required, but this warning was there from May 2020, and Windows 7 has been working until this month)… Is it a production error?
Thanks
Hey, i just upload another file. Now tabs is working for me. Can you reinstall it and check if its working?
Di18
  • December 26, 2022
Thank you so much!!! 🖤
same here, how to solve this please help
