I am trying to set up a Set Variable prototype connection with the API but when I copy the data structure for an actual “SET_VARIABLE” prototype reaction I get this error.
This is the connection I am setting up:
let getVariableReaction = (newChar, varId) => {
let newReaction = {
type: "SET_VARIABLE",
variableId: varId,
variableValue: {
resolvedType: "STRING",
type: "EXPRESSION",
value: {
resolvedType: "STRING", // <-- this fixed my issue
type: "EXPRESSION",
value: {
expressionArguments: [
type: "VARIABLE_ALIAS",
value: {
type: "STRING",
value: newChar
expressionFunction: "ADDITION"
return newReaction;
Am I missing something?? I copied it directly from what I see in Figma when I set the same interaction up in the UI.
This is what I’m copying from Figma when I look at a set variable interaction done in the UI.
SOLVED. Human error!
Needed to add resolvedType: 'STRING' in variableValue.value
