Figma's RGB color values seem to have a rounding error?
Jakob_Engelbrecht
It seems to me that Figma’s RGB color values are slightly off / have a rounding bug?
As mentioned in issue 10852 Figma’s RGB color values are in the [0, 1] range, whereas web RGB is in the [0, 255] range.
If that’s true, then multiplying the Figma value in the [0, 1] range with 255 should produce a valid value within the [0, 255] range. And similar dividing a web RGB value in the [0, 255] range with 255 should produce a valid value within the [0, 1] range.
But doing that doesn’t actually produce the correct values?
E.g. going from a web RGB value of [229, 241, 251] to Figma RGB should yield:
[229, 241, 251].map(val => val / 255);
// outputs =>
  0.8980392156862745,
  0.9450980392156862,
  0.984313725490196
But querying Figma on a node with that color fill yields:
figma.currentPage.selection[0].fills[0].color;
// outputs =>
  r: 0.8980392217636108,
  g: 0.9450980424880981,
  b: 0.9843137264251709
Comparison:
r / 255:   0.8980392156862745
r (Figma): 0.8980392217636108
                    ^ differs from here
g / 255:   0.9450980392156862
g (Figma): 0.9450980424880981
                    ^ differs from here
b / 255:   0.984313725490196
b (Figma): 0.9843137264251709
                     ^ differs from here
Going the other way from Figma RGB to web RGB yields:
[0.8980392217636108, 0.9450980424880981, 0.9843137264251709].map(val => val * 255)
// outputs =>
[229.00000154972076, 241.00000083446503, 251.00000023841858]
when it should be:
[229, 241, 251]
Has anyone else run into this issue? Or am I missing something around the conversion? 🤔 😅
Jakob_Engelbrecht
Hey, anyone…?
Maxime_Daraize
You’re not alone. I am currently facing the same issue.
Jesse_Clark
  • 4 replies
  • March 31, 2023
Any updates here?
Jesse_Clark
  • 4 replies
  • August 28, 2023
Still waiting on this one…
  • July 15, 2024
Are there any updates on this? Trying to use the /variables endpoint of the Figma REST API, but facting these issues as well.
Original color in HEX: #eae3ff.
Color after converting Figma RGB: #cde5ff
This is kind of blocking as we don’t have reliable design tokens in our design system this way…
Evelyn_Hasama
Thank you for bringing this to our attention. JavaScript floats are 64-bit, while Figma’s RGB values are stored as 32-bit floats, which only have the precision of 7 decimal places. Thus, converting web RGB values to Figma RGB values may introduce imprecision. Consider using this color converter, created by a member of the Figma community, to convert to and from Figma RGB.
