Simultaneous interactive components animation
Sandra_Gonzalez
Hi,
I was wondering if there is a way to create two different interactive components and when activating one, it activates the second one.
To give you some context: I created a CTA, and a small animation on an illustration, both work well independently while hovering, but is it possible when I hover my CTA, the animation next to it starts its animation ? (and not to have to hover each component to activate it).
Hope my explanation is clear ^^’
Many thanks in advance for your help
Sandra
Best answer by tank666
You need to create a third Component Set that will both work on hover.
In the example below, you can see that when you click on the “Add to Cart” button, a badge will appear in the navigation menu.
Figma – 2 Jul 21
tank666
  • 4870 replies
  • July 14, 2021
Figma – 2 Jul 21
tank666
  • 4870 replies
  • July 14, 2021
Yes, In order for both to change when interacting with one element, they need to be one component.
If your elements (CTA + Illustration) are never used separately, then it doesn’t make sense to create a separate interactive component for each of them.
  • August 13, 2021
