Select same Instance in prototype mode
  • August 10, 2021
  • 2199 views
Christian_Leon_Christensen
    I want to select multiple components of a menu across different frames, to easier add prototyping links to the same page. When I select a component on one frame I see that Figma identifies identical instances in other frames, but Select all with same instance command does not correctly pick those instances.
I have seceral instances which should point to a same frame, in a navigation menu, and picking all items at once will let me add a prototype link faster.
See video on Jottacloud
  • September 9, 2021
