Components should respect their alignment constraints when changing size even without autolayout
  • April 28, 2022
  • 1076 views
Svarry
See video of the issue here:
I have a component “Text” with autolayout enabled at first. Its instance is set to position center, so when I change parent’s size, it automatically grows in both directions. All good so far and working as expected, if I center-align a component I expect it to apply to all changes from component’s size to frame’s resizing.
However, once I remove the autolayout on the parent, and change its size, the instance now grows to the right ignoring the previously described behaviour. Why the inconsistency?
I can’t auto-layout every component, and it’s really time consuming to go through every usages of the instance and re-align it into middle of its parent when its size has changed. Or am I missing something?
  • July 27, 2022
