An invalid image or thumbnail was removed
Jayce_Yard
As per the Figma tips page, we have been using the “images as styles” trick to re-use commonly used images in from our team library. Whenever we try to use some of these styles however, it will be automatically removed and the message “an invalid image or thumbnail was removed” is displayed. We’ve been struggling with understanding why certain image styles are affected. Is there a way to see if an image/thumbnail is invalid and if so, how do we repair them??
Best answer by Matt_Ritter
Hi folks, this should work now, as long as you’re logged into both accounts. Please try again, and sorry for the inconvenience!
lanceplaine
I have been having the same issue for multiple days. It makes it impossible to work 😠 as every-time I touch a file it’s destroyed
louise.schaffner
Same problem here !
And I’ve seen this question under other older posts - YES I am in the same account on every file.
Flavia_Ibanez
Same problem here, it is extremely annoying. I have some images applied as styles in components from the team library and when importing the image disappears… randomly.
  • 4740 replies
  • April 8, 2022
Hey All,
Thanks for flagging this! Our team is looking into it. Can you please help us by providing more information about your files? Is the issue happening in-browser as well as the desktop app?
Daniel_Kusaka
Samie issue with me. I’m using the desktop app.
Kyle_Venn
I’m having the same issue. It’s a png file. It happens when pasting between two different Figma files on the Desktop app. The files are both owned by the same team.
Frederik_Hansen
Having same issue with a jpeg file. The image shows in the browser, but doesn’t in the Desktop app.
Update: Closing the Figma Desktop app and opening it again seems to make the images appear.
Alex_Marsh
Same issue here.
k.kartik_dora
I’m also facing the same issue
Jayce_Yard
  • 8 replies
  • April 21, 2022
Hi Dvaliao, already reached out to Figma Support directly but this issue is happening on both the browser and desktop apps for us.
  • 4740 replies
  • April 21, 2022
Thanks for the context. I can see that our support team already replied a few hours ago. Rest-assured, this is a known issue that the team is already investigating.
Tung_Bui1
The issue still persists. I have tried copy paste designs with images across different accounts, and saving the designs into Fig files, none of them works !!! This is impossible to work with, as I need to move the designs to another account for testing purpose!.
Bruce_Bowers
I am having the same problem.
Rusdhy_Jasmin
I’m having trouble when I can’t copy an image from another figma file, why is this happening? and this issue occurs or is this indeed a deficiency in one of the plans? please i need an explanation
Odama_Team
is this solved? I’m having trouble when I can’t copy an image from another figma file, why is this happening? and this issue occurs or is this indeed a deficiency in one of the plans? please i need an explanation
Jayce_Yard
  • 8 replies
  • May 11, 2022
This issue is still present unfortunately. Support is only able to provide assistance on a case by case basis, which isn’t helpful as this bug pops up very randomly.
fatima3
  • May 18, 2022
Same problem and it’s really annoying i can’t work smoothly, did any one know how to fix this problem?
liangsi
  • May 27, 2022
I found a solution! If the file you want to copy is in account a, first copy the link on the client (desktop), remember to select “anyone who knows the link can edit”, then open the link with account B on the web, and select “duplicate to your drafts”, then the file will be completely copied to account B, and the picture will not be lost!
Maac_Wong
This works.One more tip. for finishing all the above steps, now you are in account B. you may find that you are a “guest”(you can see a guest tag by your origin team name in account a) in the team of account a. but dont worry, now you can open the file and copy paste all to a new fig created by your own team in account B.
Silas
  • June 15, 2022
This issue is happening to me by just pasting an image from my computer into Figma. It’s seemingly random what file it happens to, but it’s a complete blocker on my work, as I need to paste a specific image, but it refuses to let me do so.
Patricia6
Also happening to me in-browser and it’s pretty random which images this error displays for.
JessT
  • June 20, 2022
I exported the needed images from one file as PNG and then imported them into the needed file and this worked out ok.
MathiasB
  • June 21, 2022
Also happens to me on random images…
Katerina_Rouchos
I’m still having the same issue trying to copy a png from my computer. I’m not a guest on the file and I have copied this same exact png before onto the same file but now it keeps giving me that message “an invalid image or thumbnail was removed” when it didn’t before. This is on the app. It works if I open figma on the web and add it there but then the image still doesn’t show on the app (or it takes forever). This has been an issue for at least a month now.
Anushka_Jain
I’m facing this issue as well, I need to copy my internship work to my personal profile, but it’s not letting me do so
