Is this strange jiggle while using smart animate a bug?
geor.gy
Hello guys!
I’m using Figma for about a year now — totally having a blast with it!
For some reason, I have this strange jiggle while using smart animate. I think it’s a bug because all the properties are the same. Sometimes it appears, sometimes it’s not. I did try to find a pattern, but couldn’t understand what causes it. It’s not a huge issue but kinda bothers me a bit.
I’m using the desktop app and my laptop ain’t the most powerful, so maybe it’s the root of the bug.
Also, can I post my personal website design here on this forum for a review? I’m not sure it’s a great place, but it seems there is a lot of good designers who can help to improve one’s skills, heh.
Edit: ahem, please don’t mind mistakes in the text — it’s just a draft 😁
Best answer by dvaliao
Hey All,
Right now, the only workaround to avoid seeing this issue is changing the view option to “Actual Size (100%)” for the prototype.
If this doesn’t help, please reach out to the support team directly via this form for help: https://help.figma.com/hc/en-us/requests/new
Please use your Figma account email, include a link to the file, and share it with support-share@figma.com so they can take a closer look.
Soren_Helmreich
Hey, I have this problem too.
I think it has to do with the prototype scaling options you get.
In the top right of your prototype viewer, you can select options and choose a different scaling method. For me, the only option that consistantly solves this jigglying problem is by putting it into “100% Display at full size”
Otherwise, I often use the Figma mirror App to view my designs on my phone. This one doesn’t seem to have any of these problems either.
I hope this helps, if you haven’t found anything helpful by now 🙂
geor.gy
  • May 16, 2021
Thanks for the reply! At least, you replied to my question. I think you are right about scaling thing, because I’m using “100% width”.
Alisson
  • February 15, 2022
Incredible! Tried this and the jiggle stopped! Thank you so much!
Danyllo_Henrique_de_Oliveira_L
For me, the 100% Display at full size didn’t work. It still jiggling 😦
Elayne_Rojas
I was going insane with a similar issue and this fixed it (the prototype phone was changing position with transitions/animations). Thanks!
StLa1
  • 26 replies
  • August 2, 2022
Didn’t solve the issue, it’s been around for 3+ years at this point @Figma_Support
Iva_Beleva_EXTERNAL
I am having the same issue on desktop and on Figma mirror. Auto animated loading spinner is jiggling / glitching. Sometimes it is working fine. Is there a fix for it?
jonoyoung
  • 34 replies
  • April 20, 2023
Still seeing the jiggle, no matter what view option is enabled, even when simply changing text and icon color on :hover.
Demo:
Tatiana_Martinez
Same problem 😦
dvaliao
  • 4710 replies
  • May 16, 2023
Hey All,
