New variants and disabled button for different versions
  • November 9, 2022
  • 868 views
Magda_Zawadzka
I a pretty new to the new way of building variants and I came across a problem which, I am sure, might be easy to solve but… I hit the wall.
I am preparing different versions of buttons: outlined, light and dark. With the use of Boolean I can remove one or both of the icons.
Problem: I need to create disabled variant of the button for each version of the button I created. Is there a way to do it with e.g. boolean? I couldn’t figure it out on my own.
Can you help, please as for now I have created a different component set, but I feel this is not the way to go.
tank666
  • 4863 replies
  • November 9, 2022
Remove the unused “Disabled” property in your component set. Move variants from one component set to another. Then rename your variants to something like this:
Variant=Outline, Disabled=False
Variant=Outline, Disabled=True
Variant=Light, Disabled=False
Variant=Light, Disabled=True
