Text zone issue - text overwriting
Thibaut
Hi there,
I am having an issue with my text zones, whenever I type text when it reaches the border of the frame area it starts over at the beginning of the same line and overwrite on my text . So basically the text writes over and over on the same line.
Here are two screenshots to better understand the issue. Any thoughts on that?
Cheers!
Screenshot 2021-04-20 111134
Screenshot 2021-04-20 111149
Best answer by Alexis7
Hi @Thibaut I had the same problem. In the right-hand panel, under text, the A with a horizontal line above and below it was set to zero (0). Increase it and the lines behave as expected. I have a font size of 16 and setting that A to 20 worked to separate the lines. See attached screenshot to help find the setting.
Screen Shot 2022-05-21 at 12.30.04 PM
Josh
  • Former Community Manager
  • 1019 replies
  • April 20, 2021
Is this related to Interactive Components?
Alexis7
  • May 21, 2022
  • March 20, 2023
Thank you - that helped me alot
