Hi, I’m working with text boxes and this one doesn’t seem to change the height after I increase the font size even when the height is set to hug and Resizing to Auto height. Is this expected behaviour? It clearly doesn’t play well with the auto layout in the parent element and the vertical spacing between the previous one compared to the rest is way off. If not, then how do I fix this? Thank you
Text box height doesn't hug contents
