Remove "try it out" from the Plugins menu
JosephxBrick
In Figma Community > Plugins, instead of “Install” the plugins now say “Try It Out.” I’ve read the help on this, and I still don’t understand the difference between “Try It Out” and “Install.” Both Installed and Try It Out plugins are available to all of my files, regardless of whether they are drafts or team files.
That confusion aside, how do I remove a plugin that I’ve “tried out” from the Figma Plugins menu? E.g., I tried one out, but I didn’t like it, and I no longer want to see it in my list of plugins. (I’m referring to the list of plugins directly in the plugins menu, not in the “Installed Plugins” submenu.)
Baffour
  • 53 replies
  • July 7, 2022
Agreed! I initially thought the Try It Out thing was a bug since it creates a blank file to try the plug in on. (Which doesn’t always make sense because many plug-ins depend on you having the file populated already).
I preferred the old install experience because it was easier to keep track of what I actually used. If I tried out 10 different Contrast plugins and didn’t like 9 of them I could just uninstall rather than what we have now.
jia.liu
  • July 8, 2022
I’m so confused. Does “Try it out” mean “Install and open a blank Figma file to test out the plugin”? Or is the plugin not installed? It’s doubly confusing because one of my plug-ins just put up a paywall, so I thought this was some sort of new freemium trial feature that Figma’s rolling out.
David_Bruggink
This functionality is super confusing. I also prefer the old experience. It’s so much faster to simply Install and then try it rather than creating a new file every time.
More problematically: With some plugins (as I just tried with Avatars), if you click anywhere on the page (i.e. to create a shape), it closes the plugin dialog and there is now no way to try it. This is beyond dumb.
Chris42
  • July 25, 2022
Remove “Try it out”, ridiculously confusing
Jon_Gifford
Have to agree.
Has anyone found a way to remove the “Try it out” plugins in the menu? I’d love to not see them anymore.
Mauro_Pocobelli
same issue, I hoep thay will fix it. Bad experience, I have my plugin menu very messy.
Raphael8
  • August 10, 2022
Yes please give us a way to manage installed plugins, my plugin menu s getting crowded
  • 4 replies
  • August 10, 2022
+1 this new ‘Try it out’ is such a confusing experience, prefer the old one!
Larissa_P
this is insane and now it’s just became impossible to remove/delete plugins
Nikos_Kosmadakis
yes please, before it was so much easier
David86
  • August 19, 2022
Agreed such a bad user experience decision.
“Trying it out” literally doesn´t work 90% of the time and now you´re stuck with plugins in your list which you don´t want!
JosephxBrick
  • 67 replies
  • August 19, 2022
This feature could be cool if it allowed the plug-in developer to provide a “playground” file with content that lets the user to truly try it out, rather than just a blank file. I have a plug-in that relies on a certain set of components to be available: it would be great if I could provide a playground file so the user could copy the components from it.
Otherwise, though, this seems like a solution in search of a problem.
Ben_Kopf
  • August 21, 2022
I agree. This was a swing and a miss by Figma. How do I get rid of them after the tryout? If they want to keep the same interaction model, let us try out the plugin we select on any page we run it on (or at least keep that dialog open while we add content to try out on), and have a “Keep or Remove” selection after we’ve tried it out. I’d even settle for the Keep or Remove buttons on the Try it out dialog as a quick fix. thanks
Sean_Tubridy
“Try it out” would be fine if it came after a button that said “install”. Not being able to install a plugin from the plugin page is… just baffling.
Nigar1
  • August 27, 2022
I couldn’t agree more. It is just not helpful, when I want to install a plugin I click “Try it out”. It opens a new file and I do my job there, and I think it is installed and delete the file. But apparently, it is not, so I lose all the useful plugins just because of this nonpractical feature.
  • 4737 replies
  • August 30, 2022
Hey All, thanks for the feedback!
We hear you. The new flow was intended to allow users to try out a plugin, before installing it. That said, all of your feedback has been taken into consideration for a future update - stay tuned!
JosephxBrick
  • 67 replies
  • August 31, 2022
Thanks @dvaliao!
Yrobot
  • 4 replies
  • September 8, 2022
Hi there,
Is there any way for me to update my plugin draft when users click the try button under my plugin page? For now it is a total empty canvas.
BTW, I think it would a better solution that the ‘Try it out’ button shows only if the author provide a draft, otherwise just show a install button directly.
Chrtz
  • 63 replies
  • September 26, 2022
To everybody who is now stucked with unwanted but installed plugins – it is still possible to delete installed plugins.
How To:
  • Go to https://www.figma.com/community/ and click on your profile/avatar in the top right corner
  • Now click on plugins
  • A modal window will show up and list all your installed plugins
  • To show more options click on the meatball menu icon (the three dots)
  • Click on Remove from saved plugins
  • ✅ Congrats, you’re done!
But yeah, it should still be possible to install/uninstall plugins directly from the community tab. Why not add the Try out Plugin feature as a secondary option? Would be a much better UX.
Additional note:
You also can uninstall plugins within Figma itself, by navigating to the plugins tab, open the unwanted plugin and click on the meatball menu icon to show more options. There you should be able to remove or uninstall it.
Lior_Mazza
Agree. totally confusing
Ken_Huang
  • December 9, 2022
super confusing and hard to remove or uninstall plugin, please
Marian5
  • December 12, 2022
Agreed. I am new to Figma and even figuring out how to install a plugin requires google searching for user-provided information…? I feel like the irony regarding the lack of intuitive UI design here (HERE!) is baffling. Isn’t this where designers come to make beautiful, functional content? It’s almost funny. If it weren’t the night before a project is due in my bootcamp. 😭
amu
  • January 24, 2023
Oookay, I’m, new to figma and how plugins work and how to install them was kinda confusing to me. especially since the UI guides you throw the “community” but all it does is create a new empty project (try it out) and basically all the installing/uninstalling is done via the “resources” menu-panel. Overall I think the functionality is ok, but needs to be communicated a bit clearer, especially with all the “old” tutorial content out there.
This helped.
  • April 24, 2023
