When I double click an item to rename, it stays highlighted. I can no longer click the mouse to the end or anywhere inside the name to edit. I can retype but then have to press ENTER to keep it. This used to work. It DOES work on the PAGES up top. The click/select mouse function works different on PAGES and LAYERS for some reason. This is a new thing. I closed out Figma and reopened but still does it. It does the same in other files.
The team confirmed that this is a bug that they’re already investigating and working on a fix for. We’ve merged your topic with another existing, similar one here in the community:
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
