I was breaking my head to try to remove a component variant the only way I had found was to delete the component because I could only unlink the first one, searching I found a miracle plugin, which solved my problem the name is Detach Component, I lost a good few hours looking for a solution for something simple that should be natively included in Figma, hope it helps someone
