Instance Component Auto Layout Behaviour
John_Vine
I have a master component (simple menu with icon left side, text right side) set up on auto layout so that when you hit Cmd + D on the icon and text auto layout frame that duplicated frame sits vertically in relation to the first frame, all inside the full component.
When I make an instance of that component and repeat the process (hit Cmd + D on that same text/icon frame), that new frame duplicates outside the component.
Anybody have any ideas?
Best answer by Antoine
Thatā€™t not how instances work. You canā€™t add or remove stuff in an instance (that would defy the purpose of instances). What you can do though is have a certain number of lines prepared in your master component (say 8), and hide/show them in your instance (you can use ā€œDeleteā€ for that but they will simply hide/show) to have the amount you need.
Antoine
  • 144 replies
  • May 5, 2022
John_Vine
  • May 5, 2022
Many thanks for taking the time to reply Antoine, that was really helpful šŸ˜€
