Figma powerup for Trello
Dan_Dineen
The Figma powerup for Trello has recently stopped working across all the Trello boards it has been installed on. The powerup is still installed, active and apparently still linked to my Figma account but the ‘Figma’ button (Click to add a file or prototype) has just… vanished.
All my other powerups are working fine and so I’m wondering whether:
  • anyone else is using Figma & Trello? Is your setup still working OK?
  • anything has changed in Figma or the powerup recently that might be causing issues? (There was a new Figma release this weekend. Could that be causing the problem?)
One thing I did notice was that the Figma plugin does NOT comply with the Trello privacy and data security T&Cs. That shouldn’t stop the powerup from working AFAIK but it might suggest the latest version is a bit buggier than the previous one.
Thanks for any help you night be able to provide! 🙂
Best answer by ksn
Hey all - if you haven’t already seen, I’m linking a help page we have on Trello here: https://help.figma.com/hc/en-us/articles/360039828394-Trello-and-Figma
Also – I’d recommend any questions on Trello <> Figma be pointed over to Trello and their support team for further help. Since the work is embedded within Trello itself, they would be best to assist.
Because this topic is older, I’ll be closing it. Please feel free to open a new one with any additional questions.
Isabella
We have the same problem - please reply if you find a solution!
rasangana
I have the same problem here, and I found this when I looking for a solution or what happened to that! 😅 However I also like it if it can comes with the latest version, also with less bugs
ksn
  • April 29, 2024
