Feature Suggestion: Unified Padding Control
Radhika1
Context: In Figma Design file, setting padding requires adjusting both sides (top +bottom, right+ left). While having the ability to combine longitudinal sides as one and latitudinal sides as another is helpful - it still requires to insert the same number two times(individually) for the times when the padding is same for all 4 sides for anything, which can be time-consuming and frustrating.
Idea-suggestion: Introduce an option to apply equal padding to all sides with a single input, streamlining the process and improving efficiency.
Be the first to reply!
