Wrap elements in Auto Layout to multiple lines
I would love to see a full flex-layout implementation, including the ability to set grow, shrink and flex-basis values.
+1 for this to be implemented
Adobe XD has something with a similar behaviour called Repeat Grid, which can be vertical and horizontal at the same time. If the Repeat Grid could be combined with Auto-Layout that would be amazing.
Repeat grid is a completely different behavior that what is specified here.
I believe that the official implementation of the UX of this plugin will solve everything.
Reproducing it with a hack is not realistic because there is a risk that some update will disintegrate the figma files.
I don’t understand why they defined the master component as a variants element, not only for the way Autolayout is implemented, but also for the variants feature.
It is reasonable to define the instance as a variants element and configure it with overrides
Can confirm that this plugin works great! :heart_eyes:
+1 !!!
This plugin is godlike. Exactly what I was looking for. Thanks for the tip.
I need to know how to achieve this :astonished:
+1 this feature would be amazing
Looking for this functionality as well. Native wrapping elements in auto-layout.
It would also mimic flexbox much better which should be the goal imo.
I believe this is essential behaviour. We really do need this.
+1 This feature is sorely needed. Plugins help in some cases, but you can’t really rely on them when building a design system with components.
+1 on this - needed ASAP
I think there would have to be two options for wrapping, one for columns and one for rows (like in css using flex-flow with column wrap and row wrap).
+1 badly needed
I have encountered twice already in just two weeks of using Figma. ≈
+1 for this feature. I hit this limitation all the time. The plugin mentioned above works well, but true flex-box functionality would be great. cheers!
+1 please we deserve this feature, none of your competitors do it either I think, it would be yet another reason to join your forces ! :pray::pray::pray::pray:
+1 need this!!!
