When we run prototype with no device, the whole frame is not responsive?
Aatir
Here Header is fill container and elements inside are also behave with size.
All the other sections aligns with header with same responsive style.
Still why the white space in present mode??
Aatir
  • 5 replies
  • October 3, 2024
Structure as below :
Homepage [Top Most Frame - width : 1920px - proto - responsive]
Header [width - fill container]
Section [width - fill container]
… same as above [no section is larger than header]
Why homepage frame (top most / parent frame) has white space to it’s right in proto (present mode) - no device??
Luke-Itineris
  • 129 replies
  • October 4, 2024
Can you share a proto link please?
Aatir
  • 5 replies
  • October 4, 2024
Link
Figma – 4 Oct 24
Please recheck that scaliing is set to responsive. If it’s responsive, shouldn’t homepage resize to the viewport available? Coz inner frames ‘header’, ‘section’ did became responsive to viewport.
Luke-Itineris
  • 129 replies
  • October 4, 2024
Im not sure what you mean. The page frame is responding. What else do you want it to do?
Aatir
  • 5 replies
  • October 7, 2024
Now scroll this proto horizontally. Do you see the white space? If not, increase the size of page to 2x or 4x then do the same.
My issue is why the page frame has white space to it’s right when scrolled horizontally in present mode?
rwb_marns
  • 17 replies
  • October 7, 2024
As per checking with your link, it seems working perfectly fine. If it has issues on your end, it might good if you share your layering structure.
On top of that, we can make the frame responsive with or without device.
Luke-Itineris
  • 129 replies
  • October 7, 2024
I still can’t replicate your issue.
Aatir
  • 5 replies
  • October 7, 2024
Use mouse button to drag the whole frame to left.
Attaching video link as new user cannot upload attachments.
drive.google.com
Luke-Itineris
  • 129 replies
  • October 7, 2024
Yes, this is a bug. You need to report it.
  • 2545 replies
  • October 8, 2024
Hi @Aatir ,
Could you file a bug report from here?
Figma Learn - Help Center
Aatir
  • 5 replies
  • October 8, 2024
I have reported the same. Thanks for the concern.
