When clicking color values to copy, wrong value is copied
In dev mode clicking on a color value that has an alpha set, copies wrong value, alpha and rgb values are off.
Please fix.
Ryan_52
  • 382 replies
  • October 4, 2023
Hi, I’ve checked this on my end but selecting a color value which contains an alpha channel seems to copy the correct rgb values while in Dev Mode. Can you try restarting your Figma application or clear cache and see if that helps? If it doesn’t, do you have an example video or screenshots while reproducing the issue?
  • October 4, 2023
Hey Ryan, thank you for looking into it. It is not letting me upload a video but look at the attached screenshot. Do you think designers are doing something wrong when specifying the colors?
FYI, I am using the web app and just reloaded the page before trying it out and taking screenshot
Screenshot 2023-10-03 at 9.46.41 PM
  • 4873 replies
  • October 4, 2023
Instead of #HEXA, do you want it to be copied as #AHEX (ARGB)?
You currently cannot change this for the colors section, but you can copy the color value in #AHEX format from the code snippet when the code language is set to XML.
