Uncaught (in promise) RuntimeError: function signature mismatch
Nikita_Jerschow
Running pretty much any asynchronous code will result in the error:
Is my env setup wrong? I’ve gone through three brand new project setups and get this error every time. Has anyone else faced this issue?
For context: I have an async function at the root of my project plugin code, even running
await new Promise(resolve => setTimeout(resolve, 1000)); will result in the error.
As far as I can tell the code will keep running, as long as it doesn’t rely on the asynchronous piece.
The error will only happen on the return from the await-ed funciton.
Please advise.
  • 4710 replies
  • July 31, 2021
Do you have figma.closePlugin() in the end of code? Maybe it runs before the async function finishes if it’s outside?
Nikita_Jerschow
Just verified that close plugin is not called before the plugin exits, but that’s a good suggestion.
Do you know if it might be something else?
  • 4710 replies
  • July 31, 2021
Are you loading any fonts by any chance? figma.loadFontAsync is known for throwing this error, although I don’t remember why.
Lukas.B
  • 3 replies
  • January 23, 2022
@Nikita_Jerschow Did you solve this problem in the end?
Lukas.B
  • 3 replies
  • January 23, 2022
I had the same issue and solved it with “await”.
I called “figma.loadFontAsync” in an async function, but I didn’t add the “await” statement when calling that function. So adding the “await” solved the problem for me.
Simon43
  • November 6, 2022
Maybe just a problem with Figma runnig over a longer time?
S_e_b_a_s_t_i_a_n
Also think so. After restarting the desktop application, the error disappeared.
  • November 14, 2024
Thanks, it helped me too!
