Nikita_Jerschow
July 30, 2021
Uncaught (in promise) RuntimeError: function signature mismatch
  • July 30, 2021
  • 8 replies
  • 4809 views
Running pretty much any asynchronous code will result in the error:
Is my env setup wrong? I’ve gone through three brand new project setups and get this error every time. Has anyone else faced this issue?
For context: I have an async function at the root of my project plugin code, even running
await new Promise(resolve => setTimeout(resolve, 1000)); will result in the error.
As far as I can tell the code will keep running, as long as it doesn’t rely on the asynchronous piece.
The error will only happen on the return from the await-ed funciton.
Please advise.
Power Member
July 31, 2021
Do you have figma.closePlugin() in the end of code? Maybe it runs before the async function finishes if it’s outside?
Nikita_Jerschow
July 31, 2021
Just verified that close plugin is not called before the plugin exits, but that’s a good suggestion.
Do you know if it might be something else?
Power Member
July 31, 2021
Are you loading any fonts by any chance? figma.loadFontAsync is known for throwing this error, although I don’t remember why.
Lukas.B
January 23, 2022
@Nikita_Jerschow Did you solve this problem in the end?
Lukas.B
January 23, 2022
I had the same issue and solved it with “await”.
I called “figma.loadFontAsync” in an async function, but I didn’t add the “await” statement when calling that function. So adding the “await” solved the problem for me.
Simon43
November 6, 2022
Maybe just a problem with Figma runnig over a longer time?
S_e_b_a_s_t_i_a_n
Also think so. After restarting the desktop application, the error disappeared.
Thanks, it helped me too!
Author of Variable Icons, a plugin for Figma
