Unable to delete interactions
  • January 31, 2021
  • 6 replies
  • 1253 views
Meng
Hello good Figmians! As stated in the title, I am unable to delete interactions. Meaning, even when I delete an interaction in “prototype” mode, and the prototype line no longer exists, the actual presented prototype still displays the interaction I had deleted.
I have tried:
  1. Closing and re-opening the prototype,
  2. Closing and restarting Figma,
  3. Clicking “inspect” on the element in question to make sure the interaction has been really deleted.
  4. Copy-pasting my design into a new Figma file,
    None of which have worked.
I created a screen recording here: Loom | Free Screen & Video Recording Software
Great thanks.
Bruno_Figueiredo
Quick question: do you have any of those connections attached to a Master component?
Meng
  • January 31, 2021
@Bruno_Figueiredo I appreciate the reply! Yes, I do, but I have also removed the interactions from the master component.
Fred_Tinsel
  • 113 replies
  • June 14, 2024
Same here !
I want to delete the interaction on a specific instance but not on the main component.
I am goning throught the same issue I am using MUI for Figma and I am unable to replay color or remove interactions from an instants of a main component. What properties can be changed on an instant in Figma and what properties can’t be changed?
  • Figmate
  • 2192 replies
  • August 13, 2024
Hi @Fred_Tinsel, Thank you for getting in touch with us.
Do you want to remove the variant interactions on an instance? If so, could you please try these steps to see if it works?:
  1. Go to the Prototype tab
  2. Select the instance with variant interactions
  3. You will see the variant interaction listed in the Prototype tab. Click on the minus sign next to the variant interaction to remove it
    Screenshot 2024-08-13 at 13.27.02
You can refer to the following resources for more details:
Hi @Danel_Roldan1, It seems like you are encountering issues with a plugin like MUI for Figma.
While we are waiting for input from our community, if you have any questions about using the plugin, please reach out to the plugin’s creator for assistance or to report any problems. Each plugin has its own support email listed on the plugin’s homepage. The plugin’s creator will then communicate any bugs to us.
I hope this information helps clarify things. If there is anything I misunderstood, please feel free to let us know.
If anyone in our community has additional insights, please share them here.
Thank you,
Fred_Tinsel
  • 113 replies
  • August 14, 2024
Hello @Junko3
Thanks but I perfectly know this workflow (I use it every day 😉 )
The minus wasn’t available
I remember what have worked
Restart Figma → NO
Clear Figma cache + Restart OSX + Restart Figma → YES
