SLT-UX
Active Member
April 3, 2021
Temporarily hiding selection outlines
In other design tools you can simply press a key, and any selection outlines, grab handles, etc. get hidden while the key is down, so you can preview and evaluate how things look, without having to de-select everything and lose your selection.
Apparently there is no way to do this in Figma =(
This is important while experimenting with different colors, fonts, etc., and in Figma it could be used to see how different sizes, variants, and states, look in your design, without those selection handles and outlines getting in the way of you previewing things.
Power Member
April 4, 2021
It is not possible but it sounds like a good suggestion, so I’d recommend you to edit this topic, turn it into a suggestion instead of a question, and move it to #product-ideas category.
Power Member
April 4, 2021
Also you can always press Esc to deselect everything, then Cmd/Ctrl + Z to undo deselection.
SLT-UX
SLT-UXAuthor
Active Member
April 4, 2021
Done.
SLT-UX
SLT-UXAuthor
Active Member
April 4, 2021
Yep, that’s what I have to do. But it breaks flow state. The subtle, yet magical effect of simply pressing a key down, is that it’s so simple & easy to do, you stay in that flow state as you switch options while designing, which speeds up your design evaluation process by an order of magnitude. Once you experience it, you’re kind of hooked on it 🙂
Maybe other designers here who know what I’m talking about can share their perspective on this, but for me it’s a huge speed boost to be able to do this.
SLT-UX
SLT-UXAuthor
Active Member
April 4, 2021
Also, I should add, it should be easy to implement. Huge bang for the buck.
Nadav_Savio
July 23, 2021
+1 to this. ESC doesn’t do the trick because then you can’t manipulate the selection.
Gary_Pikovsky
November 24, 2021
+1000000 to this!
This is by far the biggest design update I would like to see. Enabling hiding selection lines with a good shortcut would turn Figma into a powerhouse. I completely agree with the magical flow. It suffers without it.
Ricardo_Desirat
Voted! It could be “h” key. Does anybody uses “h” for hand tool?
Ricardo_Desirat
Hi Gleb
Sorry, a bit of but how can this be done?
I was trying in one of mine and don’t see how.
The advised one is Share Feedback and the tags don’t allow to put anything.
Thanks
By the way, the one I mention is a bit related o this, so, who wants to take a peek…
Power Member
January 14, 2022
This topic is already in the correct category. Product Ideas were renamed to Share Feedback.
