SOLVED: Differentiate vertical/horizontal item spacing values in REST API response for wrapping auto-layout frames
Simon_Steer
I noticed that auto-layout frames now support wrapping items to the next line, which is really great to see 🙂
Since users can now specify both vertical and horizontal item spacing values in wrapping auto-layout frames, this should be returned in API responses as well. Currently item spacing is represented as a single field, itemSpacing, which only takes into account spacing along the primary layout axis.
I propose adding a new field, counterAxisItemSpacing, or something similar, to represent spacing along the counter axis.
For the following example:
Screen Shot 2023-07-10 at 3.52.37 PM
The JSON response could look like this:
itemSpacing: 10,
counterAxisItemSpacing: 35
As far as I know this would be a non-breaking change to the API.
Cheers and thanks again for adding wrapping to auto-layout frames!
Best answer by tank666
The counterAxisSpacing property is responsible for this.
https://www.figma.com/developers/api#:~:text=auto-layout%20frames.-,counterAxisSpacing,-Number%20default%3A
  • 4873 replies
  • July 10, 2023
Simon_Steer
Ah, I see it now. Can’t believe I overlooked this! Thanks for the heads up.
