Smart animate issues
  • August 14, 2024
  • 22 views
Loraq
Dear all,
Created an animation using a component with variants.
However, running into these two issues:
  1. The images fade out to white and then pop up.
  2. The image on the far left moves along a strange path, it should move directly to the right.
I have taken care with the naming so that Figma can animate to components with the same name.
Here’s the Figma file: https://www.figma.com/community/file/1405566471837534213/smart-animation-issue
Here’s what I see when I run it:
https://youtu.be/epexI4P1w5E
Hope someone can help!
Thank you,
Lora
  • 2545 replies
  • August 21, 2024
Thank you for reaching out and sharing your file on the Community; it’s really helpful! When I tested it, I encountered the first issue once, but the second issue did not occur. This seems to be a rendering issue due to the large file size. Upon checking the file, the frame appears to be quite large.
So, I tested [Downsize]. Here are the results of my test:
I’d suggest checking if the frame and image sizes really need to be that large. You can also find more tips to reduce file size and improve performance here:
Figma Learn - Help Center
I hope this helps but please feel free to let us know if you have more questions!
