Smart animate for frame with stroke glitching
Keith_Vaz
I’ve applied smart animate to my interactive component. Its got a stroke applied to it with a radius of 16px. Every time it expands and collapses the stroke glitches and pixelates. Any clue what’s causing this? Is it a known bug?
  • 4710 replies
  • April 1, 2021
That’s not related to interactive components, it works this way with Smart Animate in general. Stroke + corner radius animation is not supported yet so it simply animates the transition between two raster images. Example: https://figma.fun/l4x8m3
Keith_Vaz
  • April 1, 2021
Thanks Gleb for the response. My bad I wasn’t aware of this being a smart animate bug in general. Looking forward to a fix for this in the future 🙏
Samantha_Pecan
I’ve had this issue too and found a work around if you’re interested. In the image below, I used a frame that is the size of the overlapping area between the two rectangles and set it to clip content (I turned off clip content for the image so you can see how it’s working under the hood). Inside the frame, I have two rectangles with the desired corner radius and outline. The second state of the component is the size of the filled rectangle. On the transition, I have the top one (just the outline) slide down to be in the same position as the filled rectangle and expand the frame to fit the expanded rectangle size. Hope this helps!
Dennis_N
  • 191 replies
  • May 30, 2023
Unfortunately this glitch still persists 😔
Garret_Schauteet
Anyone trying to animate strokes still, use a drop shadow at 0px blur and 1 px spread - increase spread to increase stroke size. Will animate fine, Gleb just shuttin down peoples dreams over here. 👍
Matt_Walker3
This has been an issue for a few years now. Any traction on getting this fixed and introduced into a Little Big Updates release?
Dmitry_Lyapustin1
Issue is still there… It’s time to solve this, Figma 😉
Janne_T
  • January 24, 2024
90’s new media heroes may remember the “nested html-tables”-hack: Nested tables with backgound colors and 1px padding enabled revolutionary 1px colored borders on the layouts.
In fact, the same logic can be used in Figma to tackle the ugly border animation -issue. I just had to try. It works. The “faked border” component animates smoothly. (it would be embarrassing to run glitchy and visually imperfect demo and blame Figma… - even Figma is to blame)
hack
Of course hacks like this can’t be the solution, Figma should fix the issue.
Hope this helps.
  • June 17, 2024
This bug still persists over 3 years later.
Please Figma, don’t go the way of Adobe and let simple bugs hang around for years and years.
Valeriia_A
  • August 9, 2024
Still persists even in the shiny and new UI3. Please, fix this bug.
Deviers_Alexandre
You can fix it by using dropshadow without blur… but it’s again a trick not a real fix
Deviers_Alexandre
Oh saw someone already post the same trick …
Courtney_Comfort_he_him
I am also having this issue in a prototype. Figma, please fix.
