Shortcut to publish library and automatically update files
Fernanda_Ruiz
My team and I are currently having the inconvenience of having to publish our library every single time we make even a small change (like a font size increase, color change, etc.) and then switching to the working file and manually updating the library. Due to the nature of the project we do this quite frequently and having to publish – switch file – update every single time to see the changes in our designs turns out very time consuming if you add it up.
It would be amazing if Figma could integrate a shortcut for automatically updating a library and automatically updating the files it is being used on (like a cmmd+S shortcut!), of course not everybody might want to have this so it would also be nice to be able to turn this shortcut on and off.
Chris_Johnston
This is bugging me too. I can see thee value is huge organizations but for a small shop wanting to do things right, its a waste of time. Wish I could select autopublish. Thanks!
Melissa_Samworth
Yes I could not agree more! I am actually the only designer on my team, but I like to centralize my design system. So I’m constantly publishing updates to myself, and going through this whole process! Haha. It is annoying.
  • November 1, 2021
StLa
  • 5 replies
  • December 3, 2021
  1. Right now the publication flow is very long and heavy, even for small updates.
  1. Alt+3, 2) Publish 3) Publish 4) Switch file 5) Review 6) Update
  1. A solution would be to offer a “Quick Publish” option for files.
    Hit Alt+Maj+3, everything is published, and files that depend on the library update automatically.
Devin_Schvaneveldt
Autopublish please 🙏
Travis2
  • 77 replies
  • December 8, 2021
Designers will hunt you down the first time you force-push an update that breaks their overrides.
What I would love to see, because it’s risk-free, is the ability to force-push updates to component descriptions. Sometimes it’s helpful to edit your instructions or to insert new keywords, but getting designers to accept updates on a component - even when it’s literally no risk to their designs - can be difficult.
Fernanda_Ruiz
That’s why I proposed this feature to be optional for a team project because not everybody would like to open their files and see things changed
Dee_Arvanitis
This should be optional on a per-user basis. We have a complex app and it’s maddening to do this from tens to dozens of times per day. Not expected in a power tool.
Sam33
  • December 20, 2021
Also agree! The workflow is too long. I need a way to auto-publish library changes and have those changes be automatically reflected in the file i’m using the library in.
Adam
  • 47 replies
  • December 20, 2021
Users don’t get updated, files do. So it would likely have to be a per-file basis.
James_McGee
Yes!! This is driving me crazy having to make a small change in my design system file, publish, swap to design file, update, and all over again if it’s not right.
Dario_Stefanutto
I would love to have the option to autopublish components and styles. It would save me so much time and energies.
I’m the only designer in the company so I don’t need to approve other people’s components.
Dario_Stefanutto
Even a plugin would be enough!
Alfonso_Ponce_de_Leon
Need this too!
Livia1
  • February 1, 2022
Please figma, this would add massive value. It should be an option that can turned on and off.
joshmillgate
Please add this feature to Figma!
Thomas_Switzerland
If you update the assets and you want to deploy them. So you should be able to do it with keyboard shortcuts. If you press the key ctrl+r you should get a preview with enter you can confirm it. If you want to publish it directly without preview, then press the keys ctrl+shift+r.
If you receive an update, you can confirm it with enter.
Thomas_Switzerland
I’ m for ctrl+r because it is already in the browser like this
Marisol_Lopez
It could also give you the otion to choose the files you want to publish too and batch it.
Olha_Kirdiaieva
Started working on a project with a component library in another file. I am already tired of endlessly publishing the small changes that I implement and want to be synchronized quickly. It would save me so much time if there was an option to simplify this process 🙏
Chelms_Varthoumlien
This would be amazing as well. Particular use case would be for project covers. I would love to make the update on the design system and have all project covers updated without having to go into each project and update them individually.
Nic_C
  • 8 replies
  • May 11, 2022
I was looking for a shortcut to this and I got in here but I see that there isn’t a shortcut yet 😪 so just voting for implementing this!
I hope this come out soon!
Alborz_Heydaryan1
This would be a fantastic addition to Figma.
When updating the library, in the window where you select the components there should be a checkbox:
☑️ Automatically update all files using this library
Benjamin14
I don’t even need updates to be automatic:
Simply adding keyboard shortcuts like Tab to browse the Libraries/Update popup tabs, and Enter to publish or update instead of having to click these buttons manually every time would already save a LOT of time (and frustration)
All you would have to do is press Alt+3, then Tab, then Enter.
deletedlc
  • 46 replies
  • August 16, 2022
Aug 2022 and we are still waiting for this… low key sad.
Somehow to me, having changes made to the already published libraries automatically pushed to any and all files that use that library is so much of a no-brainer that it’s expected to work the same way as Figma’s auto-save. If auto-save is a thing, why is auto-publish not?
