seems like figma got so excited about the fact that they could, that they forgot to ask if they should.
this should be a user configurable setting.
i would think this should be off by default as has been said. at no time have i benefited from this feature and now it is actively impeding my work. granted i can work-around it by creating two distinct text boxes that appear as one, but i should not have to.
i also think this setting should be file specific, as it seems very likely that in one file a designer might want this (not me personally, but there must be people that like it), but in another file this might be unwanted behavior.
until the automatic lists can be styled to suit the project, i do not ever see this feature being of any value. figma is not a word-processor and the automatic list feature in ms word is problematic. i have seen myself and others fight with it so often to get it to do what we want it to, that it takes more time than just manually indenting and numbering or bulleting. and microsoft has been working on that for decades. that is why i use indesign or sublime text for any word-processing i need to do.
the auto list feature was an ill-conceived, poorly implemented waste of effort. should have spent the time on branching, auto-layout fragility, nested component controls, or any other of the so many feature requests on this forum.
Describe the problem your experiencing and how your idea helps solve this
I want to have text that starts with 1. but does NOT trigger the numbered list feature, right now I can’t simply toggle the numbered list formatting off. To work around I have to start with another number then go back and change it to 1.
Add as much context as possible (screenshots, Figma files, mockups, etc.)
Ask questions to bring the community into the conversation
(e.g. Does anyone else experience this? Is anyone using a plugin or workaround to help solve this?, etc.
Whenever I try to make a listing starting with 1. in an auto layout and I try to make the first row of the table Figma turns it in to a bullet list automatically, however I don’t want to use it, because I want to use check box or any other object with it (and measuring it out would be a pain in the …), so I want to make individual rows with 1., 2. etc., those aren’t in a bullet list, because this way ruins the base line and slightly changes the numbers stlye. I tried to simply turn it off, but that way removes the number.
100% these should not be automatic.
If you try to turn OFF the bullets, it removes the number you typed.
My workaround has been:
Type the number and period, but don’t put a space before the copy. Type Any Letter directly after the period. Then type a space before your sentence. Then delete the extra letter at the beginning.
ie.
First: 1.A The big bad wolf.
Second: Delete the “A”.
Result: 1. The big bad wolf.
Thank you very much guys! I’ll try both of your solution. These kind of things slows down the workflow a bit and it annoys me. I hope Figma makes it optional soon.
Was there any response to this? I need to type a - followed by a space and some text and every time Figma “helps” me by turning it into a bulleted list.
I do not want a bulleted list. I want to type “- or -”
Here’s the thing…there’s already a keyboard shortcut to create a bullet, and if Figma wants to turn that into a bulleted list - OK fine. But this isn’t a note-taking app.
The fact that I cannot figure out how to disable this poorly thought-out feature is mind-blowing. Like…pick up a gun and blow my own brains out.
C’mon guys…make this optional. It’s stupid to insist that anytime you type a dash or a number (or a bullet…which again…already exists if that what you want to create) that you are trying to created a bulleted list.
The first item will be formatted differently and fixing it causes extra work, please add an option to turn numbered formatting for any number, not just 1, or the option to disable auto-formatting.
It could be a cool feature, but currently, in most cases, it is just annoying!
Appreciate you sharing a workaround. To be honest, this only further demonstrates the needless and annoying things that Figma users need to do to compensate for the absence of a very basic functionality.
Not trying to rip on Figma because I am a huge fan. But I feel features such as this are no brainers and really shouldn’t take so long to implement.
I am currently designing a bank app with A LOT of “first of the month” dates … and every single time it converts the date into a list. I am going insane about this.
Yeah. Um. I’m really growing tired of the over auto-this, and auto-that we seem to be baking into our apps. This era of “predictivity” is starting to interfere with being able to work efficiently; not to mention a form of crowd control which goes against the very nature of creativity. I can’t believe Figma just assumed everybody would need/want to detect a 1. as a bullet and auto format! This predictive feature is more annoying and time consuming than it is helpful.
Although I find it mostly useful. If I really struggle with something like writing dates, I add some special character in front (eg. writing “+1. January”) and when I’m done with all entries I remove the special chars with some plugin like “change text”. Also just hitting CMD+Z is not the worst experience…
Please, Figma team, add the option to toggle auto formatting on/off! It’s a nightmare when writing dates, especially in languages like Czech or Slovak where we write dates with periods and use spaces between D and M (= 24. 12. 2023). Please!
