Carey_Smith
Apr 15, 2021 6:56 PM UTC
Setting to turn off automated lists
Does anyone know how to turn off Figma’s auto-formatting? I’m trying to type '- ', but it looks like Figma is assuming this text must be a bulleted list.
I’m having a similar issue when using text that’s in the format of an email address or a url. Figma is changing these to unwanted links. I’d like to turn off all text auto-formatting.
Shawn1
Aug 13, 2021 8:53 AM UTC
I have a numbered list that continues on the other side of an icon so it will need a separate text box. Please allow list editing capabilities
  1. input any start number
  2. adjust the amount of indent
OR
  1. allow indentation from line to line in a paragraph through use of space/tab to “fake” a numbered list as you can in word processing software.
Shawn1
Aug 13, 2021 9:02 AM UTC
Hi - I have a work around for list items in separate boxes
Make one list.
Create a frame.
Copy and past framed list and adjust to fit the next menu item.
Not optimal but it does work for my purpose.
Would be nice not to have to go through the formatting headaches though.
Please consider updating this feature!
Thanks
Figma_Bot
Aug 16, 2021 5:41 AM UTC
So annoying, It should turn off by default.
Aug 20, 2021 7:34 PM UTC
seems like figma got so excited about the fact that they could, that they forgot to ask if they should.
this should be a user configurable setting.
i would think this should be off by default as has been said. at no time have i benefited from this feature and now it is actively impeding my work. granted i can work-around it by creating two distinct text boxes that appear as one, but i should not have to.
i also think this setting should be file specific, as it seems very likely that in one file a designer might want this (not me personally, but there must be people that like it), but in another file this might be unwanted behavior.
until the automatic lists can be styled to suit the project, i do not ever see this feature being of any value. figma is not a word-processor and the automatic list feature in ms word is problematic. i have seen myself and others fight with it so often to get it to do what we want it to, that it takes more time than just manually indenting and numbering or bulleting. and microsoft has been working on that for decades. that is why i use indesign or sublime text for any word-processing i need to do.
the auto list feature was an ill-conceived, poorly implemented waste of effort. should have spent the time on branching, auto-layout fragility, nested component controls, or any other of the so many feature requests on this forum.
Power Member
Sep 3, 2021 11:24 AM UTC
I totally agree, pressing Cmd/Ctrl + Z after every list item when you don’t need a list is super annoying. I want to disable this feature!
Dima_Zhukov
Sep 14, 2021 1:33 PM UTC
For example:
  1. Item Name
    Item description
  2. Item Name
    Item description
  3. Item Name
    Item description
The first item will be formatted differently and fixing it causes extra work, please add an option to turn numbered formatting for any number, not just 1, or the option to disable auto-formatting.
It could be a cool feature, but currently, in most cases, it is just annoying!
ose.design
Dec 15, 2021 8:21 PM UTC
If you:
  1. Type the numeral ‘1’.
  2. Then hit space and type a full stop/period.
  3. Then return the cursor to before the ‘.’.
  4. You can hit backspace to format things correctly.
  5. And then the indent is not applied.
And no, there was no need to use a numbered list to explain this.
MitchR
Feb 12, 2022 1:13 PM UTC
@ose.design Cool solution. Thanks.
Christina9
Feb 24, 2022 2:19 AM UTC
Appreciate you sharing a workaround. To be honest, this only further demonstrates the needless and annoying things that Figma users need to do to compensate for the absence of a very basic functionality.
Not trying to rip on Figma because I am a huge fan. But I feel features such as this are no brainers and really shouldn’t take so long to implement.
Power Member
Feb 24, 2022 2:21 AM UTC
I think this workaround is simpler:
